So discription or change name
I got a power switch with 6 nodes on them.
In the dashboard/app it only show the room name. So there are 6 power switch with the same name (room + type).
Can i change the name or show the discription?
Replies (8)
Click on the right of your device, it should open a pop-up, then you can choose a suffix and since few days, it is possible to add your own suffix.
Have a look to this issue: http://community.zipato.com/responses/module-name
You can vote and see that they are trying to find a better solution :)
Thanks Fred. But it's not working :(
I get:
/j8cmTBWI2gtmAAAAABJRU5ErkJggg==
Your module is not supported (POWER_SWITCH_BINARY let me think that and in bottom left it is not written supported...), you should do a screenshot of the root of your module in order to have the UUID. Zipato team will add it to the database. It may takes some time. Anyway this is my guess, I'm not sure ;)
Maybe your right
...i'm using the Green Wave power nodes 6. They are working (can turn them off/on) but power meter is not working the way is should be.
I will contact zipato.
Thanks!
3
I saw there was a bug with suffix name (location.customsufix was all the time).
Now it's fixed, you need to change suffix from dropdown to something else, then return it to desired value and save.
Great! Working now!
