Find a solution to edit the weekly program of the thermostat without "redoing it"
Guest shared this idea 12 years ago
Planned
It is not easy to see at what time the temperature is set. Because when we set a temperature at 8:15 for example, it is displayed at 8:00. I understand that it is complicate graphically to do it.
My idea would be to :
- try to display the time (I am not sure it is a good idea)
- give the possibility to edit an area (may be it is technically complicate), I'd like to do a right click on an area to edit it because at that time I need to redo it without knowing what was the exact time set.
Or some others solution... :)
We have that in plan, but like you said it's graphically and technically complicated.
As a first step we will just display the time (maybe add edit) and later we will redesign this component to be more usable.
great :)
