When is power module deliverd
Klaas Baarssen shared this question 13 years ago
I've heart that there will come a power module. Could you say when?
Could you also say how that works? Does the power module log water use/gas use/energie use and sun collector?
Replies (6)
Power module is planed for end of March. It will measure electricity consumption of up to 4 electricity circuits, and it will power up the Zipabox composition once you put it in the fuse box (din-rail). It will be expandable, so you will be able to add up to 20 more ampere meter clamps to it, by using power module expansion units.
Does the zipatobox has a way to log the gas use/water use?
Could the zipatobox use the 'slim enerymeter port' because an ampere clamp is not precisely.
3
As far as I know, you can use NorthQ pulse counter for gas/water meters. Also, there are some Z-wave water meter (I think Secure is the name of the company). Regarding the ampere meter clamps, those will be very precise. You will have phase and zero wire connected to the Power module, so there won't be any guessing regarding the voltage (which is the main reason why "clamps only" meters are not precise).
Ok thank you, When the module also knows the voltage then it is ok.
I have one question more.
Is it possible to create a graph with calculated power consumption. For example: Create a graph with the usuage of clamp 1, 2 and 3.
And create a graph with usage of clamp 1, 2 minus 3 (sun collector).
When the power modul is planned to be realesed?
Thank you
