Virtual thermostats - API
Dev Smalt shared this question 3 years ago
We need help to understand how to fully use the virtual thermostats.
Before we could use the topic "/thermostats" to get the virtual thermostat's config where we could get "presets", "vacationPresetName", "vacationStart", "vacationEnd" (...) but I do understand that is not supported anymore .
15bf28cd956d071fa32e56f04857fef4
3f561cbe869ece32fb70bb942a183e27
Do you have any documentation on how to use the virtual thermostat with the API ?
Thanks in advance
  1. Documentation: Refer to the latest API documentation or user guide of the platform you're using. Updates or changes should be mentioned there.
  2. Support or Community Forums: Many platforms have community forums or support channels. They can be invaluable for clarifying changes or finding workarounds.
  3. Alternative Endpoints: There might be a new endpoint or method to fetch the data you need. Again, the documentation is the key. TellTims
It appears that you are looking for guidance on how to fully utilize virtual thermostats but have encountered changes in the API or system you are using, specifically the removal of the "/thermostats" topic that provided thermostat configuration details, presets, vacation settings, and more. To make the most of virtual thermostats in your system, you may need to adapt to the new approach for accessing this information. QR Code Scanner
