PHILIPS HUE
Frederic Thielland shared this question 11 years ago
Hi! I jus went through the installation of the box. Having said that, I have HUE bulbs at home but could not install using the option HUE when adding sensors. Is that normal? Do we need the additional module for Zigbee?
Yes
I guess you will be able to add the Hue bridge so you can control the devices.
For as far as i know it would not even possible if you had the Zigbee addon for the Zipabox since Phlips is "off standard" with Zigbee......
I can control the lights using http commands on the Zipabox for now and hope that adding the bridge (when we have the new firmware) would make it easier
