Horstmann HRT4 installation step by step....
Carl-Johan Bonander shared this problem 11 years ago
Can not get Horstmann HRT4 work after I connected it to Zipato box how should I connect it to Zipabox and make it work as part of the " Climate" setup . Anyone have a working setup? Help .....
After having successfully connected Horstmann HRT4 to Zipabox then is it no longer controls the SSR303 unit?
Have read .
http://www.zipato.com/UserDocsImages/Horstmann/HRT4_inc_exc_wake_up.pdf
and
http://www.zipato.com/UserDocsImages/Horstmann/HRT4B-ZWManual.pdf
Do not understand the order and command to push in order to get both zipabox and HRT4 work together.
citat:
  • It's a good idea to reduce the Wakeup Interval from it's default of 1800 seconds, for testing I used 300 seconds (the minimum wakeup time is 240)
