Rules, and 2 thermostats
Is there some reason, why i can't control more than one thermostat via rules? Is it a bug, or intentionally made feature?
This one i would like to get answer, although here is lot of other questions also without any react from Z-team. Many of them are worth to get decent answer. If Zipato can't offer documentation and instructions, they should take care these questions, really.
Not sure what you mean, but you should be able to go to climate and click on "Add new"
You can now select Thermometer Input, Cooling input/output, Heating input/output.
After you refreshed you can go to the Rule Creator and you will find the thermostat under Devices which you can use in the rules.
Hope this helps.
Slashroot
Hope this helps.
Slashroot
No, you didn't get it, or i explained bad. I have two thermostats, but i can set only one's "heating target" via rules. The other won't do anything. Not, when i try in one rule for both, or in separate rules. Only first activated rule works. If i disable the first rule, then the second starts to work. And, if thermostats are in same rule, only first in order thermostat change "heating target".
Somehow i think, that it is misuse of ticket system, if i have to open a ticket for any tiny, but to me important question.
