Help with configuring a garage door
I've connected my garage door opener with a Fibaro FGS221 (v2.1) to Zipato. No problem on opening, closing etc but I need to press on wait for a second and then press off (to ensure the power doesn't stay on). It should be some smarter way of doing this, any suggestions?
Hi again, I've figured it out. Created a rule that checks the status of the garage door and depending on the result open or close the door... as for the relay switch I created a rule that swithed the switch of after 2 seconds (not an ideal solution but it works).
But please take the time to write a manual... and maybe have a section in the community where you gather rule creator samples (screenshots and short description) - would be so much easier than to have to browse through the web every time you want to do something.
I've got a FGS222, the first relay for opening the door, the second one for closing the door.
They FGS222 is linked with wires to my garage door remote. The Zipato is configured as follow : Auto off time relay :1 second; switch type : monostable.
It works fine with my iphone.
Also the qubino relay has an auto off in the configuration settings. I use the 24v dual relay with a auto off of .5 seconds. Works well. One relay for up and one for down, but I always add a door sensor to be sure too.
