Firmware 0.9.999.4
Anyone experience with the new firmware 0.9.99.4?
Regards,
Slashroot
Updated. Everything works but my Foscam 9821V2 - but did not under FW ..3a allthough.
Firmware Version 0.9.999.4
Fixes:
- General: fix for defunct/deleted devices consuming resources
- General: added MTU config
- General: API 2v speedup
- IP Camera: zoomIn/zoomOut fixed
- IP Camera: improved detection of Foscam cameras
- ARW: network renamed to ARW
- ARW: fixed battery status reports
- Z-Wave: Z-Wave+ fixes
- Z-Wave: introduce Notifications cluster for sensors with multiple discrete states
- Z-Wave: fixed threading issues
- Z-Wave: lower thermostat setpoint precision to increase compatibility
- Z-Wave: added workaround for Qubino thermostat modes
- Z-Wave: ignore consecutive WUN's received within a certain timeframe
- Z-Wave: do not blindly send TAMPER ON when state is false
-Z-Wave: do not set onlineState of keyfobs- Alarm: added support for silent/disabled tamper
- RF433: added support for nexa: NEYC-3, LMLR-710, WRR-1, ECMR-250, PBR-2300, LGDR-3500, EYCR-250 MLR-1105, TMT-918
- UPB: support for PulseWorx PIM-U, LM4-1m, WSD1DL-6W
Fixes:
Where do i find this?
Cannot upgrade. Installation fails. See attachments.
Is it possible to retrieve a debug log to determine the cause ?
Using ZipaTablet?
Using ZipaTablet?
I am using Zipabox. Accessed through a windows client via the web interface. Tried two different browsers just to be sure, but I guess the error happens on the server/zipabox side.
Same problem here. Used Safari and Chrome browsers on Mac and iPad. None of the combination work...
My error message slightly different. It states"Failed to execute action!"
my aeon labs smart switch gen 5 is still showing wrong power consumption reports.
1 light (12Watt) shows 0.06W. anybody else this problem.
re-joined the device without improvements.
I can't find the answer to the following question :
My rules creator is acting strange with the new firmware. I can not remove anything from my rules, when I drag for example an if statement from the rule it pops back from where i draged it.
If I have a long rule I cant drag a new if statement to the bottom nor can I attach it between two if statements. This is anoying as I want to do changes and add some things in my rules.
Anyone with the same problems or a solution?
I second/third the comments from Christophe and HeroS - where is the "Alarm: added support for silent/disabled tamper"?
/Marcus
/Marcus
