How configure indoor multisound siren
Pepe Rubio shared this question 11 years ago
Hello all, and thank for your help
I am trying to configure the siren, with 2 different sound, when one of the motion sensor is activated, the siren has to sound like a Bep-Bep, but if the motion sensor is others, has to sound like emergency sound.
In the instructions, says:
The device supports using SWITCH_MULTILEVEL SET to play the sound. The sound ID is defined as follow:
1 or 255: emergency Sound
2. Fire Alert
3.Ambulance
4.Police Car sound
etc
6-99: Beep- Beep
Can somebody help to me to configure the rule to selec the different sound.
I am trying to use the command_class_switch_multilevel but I have no idea how to do it.
Replies (6)
Sorry, this is not an idea
Solved with the las beta.
What device is this?
How did you do this? The TSE03 door bell can have multiple sounds too, but no idea how to choose them?
You can't change the device config if it is not avaible in the rule creator.
I have the solution to select the sound in this Siren. We must to add //action - goto value - "and the number of the sound", higher 7 is always the same
I attached a picture with the rule....
