virtual weather station api
Andreas Eiter shared this problem 2 years ago
the api changed on openweathermap (V2.5 -> V3.0)
when comes the update? i make a new plan on openweathermap, but the device doesnt work.
I ran into the same issue when OpenWeatherMap updated from V2.5 to V3.0. After making the new plan, my device also didn’t work as expected. The integration likely needs to be updated to match the new API version. I recommend checking the documentation for any required changes or updates in your API key setup. If it still doesn’t work, reaching out to Zipato support might help clarify any compatibility issues with the new API. Hope that helps!
