Run a rule when arming alarm failes.
Patrik Gibson shared this question 11 years ago
Would like to run a rule when Arming failes because of a zone is in wrong state.
This would make it possible to alert me when using keyfob about the failed zone.
Anyone know if this is possible?
So is this the requirement?
REQUIREMENT:
Allow an event to be captured and seen in the rules creator when attempting to use Quick Arm (e.g. via a keyfob) when one of the configured alarm zones is in the incorrect state. In these cases it will fail to arm.
I suggest that there needs to be an addition to the alarm partition configuration that allows the customer to decide on what to do.
either:
a) raise a second type of squark output
b) ignore and bypass the zone
I believe that the current Zipato offering does not allow you to capture this event when Quick Arming.
/Marcus
Should not be to hard....something like this.
When key fob button 1
Wait xx sec
If alarm=armed
Send notice to on
Else
If alarm=disarmed
If doorsensor= open
Send notification
Etc
