keep light on while motion detected - rule help
Henk Jansen shared this question 13 years ago
I've got this rule, that uses a Aeon labs multisensor (timeout after no motion=6s). Light goes on when motion detected, it should go stay on as long as there's movement in the hallway. it doesnt work like this, I also tried to work with 2 rules, and turn the light off with a no motion action, but that didn't work either...nuhtJSdTfPm14jiObFBC
Replies (6)
Your rule shoul look like this:
B5AzH620jUfUuYCOZm1h
what should we do without Nenad!
Hi Nenad, found out a problem with this rule, but you couldn't know.
"motion sensor 'any' " isn't working here, because it also turns the light on every time temperature/humidity are measured (it is a multisensor). So i changed it to
MCf5UNHeHrieoJ4BELER
sorry , but what is the function of the rule "join" ?
it appears my rule also doesn't work. Luminance keeps turning on my light, i don't even use that in any rule? The light is also on 59 or 60% sometimes? weird...
nsLVuu2RiptXcR1tF24g
http://community.zipato.com/responses/how-does-the-controls-join-and-stop-function
