Compatiblity Blyss 651332
William shared this question 11 years ago
Does the zipato is compatible with this reference ( 651332 Blyss - shutters automatic ) because I can not find it in the list of modules integration .
There may be a compatible reference ?
Thank you for your reply.
William
there is not a person of Zipato team to answer this easy question.
thank you
Hello Blyss devices will be available with the release of the new official firmware. If you can't wait that long just upgrade to beta and it should work. Try adding it as some other Blyss On/Off switch since Blyss 651332 is not supported yet and it should work.
I bought automatic shutters but impossible to associate the module with the zipato . Same for the remote supplied with the kit yet is recognized in the list of modules. When I go on the site to the association, the recheche never stops. What to do to make it work?
I still can not run the module.
I tried on several different modules but it does not.
Which module name , do you recommend to integrate ?
When will be performed the update? It's very long !!
