Simple Switch turn on socket Problem?
Jacob Wiqvist shared this question 11 years ago
Hi Zipato forums!
I have problems with a simple thing.
1) I want my wall socket in the kitchen to be a timer controlled socket.
2) I want the timer to switch on the socket by a spring-loaded Z-Wave button.
3) I want that if I press it again, the same button when the timer is on, the outlet should shut off.
These simple stuff should not be that difficult. The problem is that I do not know what does what, or what the different parts in each unit is?
What determines whether a switch is a toggle ON or Off?
Do you control it through the device, or the rule or both?
Can I get help to create a rule for this, I would be very grateful.
Could I find out more about how each unit under devices work, I would be very grateful.
Best regards Jacob.
https://www.youtube.com/watch?v=rjDh-iai8p0
Replies (10)
I don't know if HeroS review is old or if have changed but he say in this review that Fibaro FGS211 dose not work with Zipabox?
http://www.domotica-blog.nl/post/fibaro-fgs211-3kw-review
Zeer stabiel/werkt altijd
Klein
Geen energiemeting
Schroefjes zijn lastig vast te schroeven
Extra schakelaar niet werkend te krijgen met de Zipabox
In your video the Auto off Timer 15 is Disabeld?
way don't you use the wait blok from the rules and turn the switch of afer the wait 15 sec -> off
IFF switch ON
Socket ACTION = ON
WAIT 15 sec
Socket ACTION = OFF
Did what you told me, i think:-) but maybe it is something wrong? Really apriciate your help Lars!
It is easy to feel stupid when things not work!
http://youtu.be/9fcu1odsu-8
f4e5a7216105cc2ed5b3271d39a18c50
WHEN INPUT 1 TEST2 SENSOR ON should be -> SENSOR ANY
Slashroot big thank you. Any chans you can explain why it works?
Finally got it working, but why? In my world if I put a switch to ON it should send a ON signal, regardless of Rule creator, as in real world. And that on signal should trigger the rule?
Then I have the other things of how to create a rule, so when I push the switch again and the timer is ON the socket turns off?
Then I want to create a virtual switch that will trigger a schedule. Socket on 04:50 in the morning. And of course the 50 min timer should turn it off. What ever is triggering the socket, I don’t want it to be on more than 50 min.
Thanks in advance!
This did not work:-)
a1fa8b3b1d4f6d3b74dc780051c8d2ca
Your IF conditions doesn't make too much sense, as they are the same as the trigger event (input 1 test2 any). From your rule, I don't really understand what is the goal, but I think something like this should do the job:
WHEN input 1 test2 ANY
-JOIN
-IF input 1 test2 ON
--IF kok vaggutag SENSOR ON
--kok vaggutag ACTION OFF
-kok vaggutag ACTION ON
-WAIT 25 seconds
SAVE
If you meant like this it does not work!
f4a4271f7f3d96d800066851b412faef
And now the socket will not turn of at all after 25 second and also what will happened if you turn on the socket with the App?
Sorry I was too fast. There are few problems with this rule:
1. whenever you press INPUT 1 TEST2 OFF after ON, it will kill the 25 seconds delay
2. second condition will execute each time, as there is no STOP (I forgot) after the first one
So, in order to make it useful, you should to the following:
WHEN input 1 test 2 ON
-JOIN
--IF kok vaggutag ACTION ON
- kok vaggutag ACTION ON
- WAIT 25 seconds
- kok vaggutag ACTION OFF
in this case you don't need STOP, and pressing OFF won't harm.
What is wrong this time? Any way a sulotin for everything would be good schedule and virtual switch and so on.
Does not work!
9172b54f46831cb197bc1841fa50fc01
You should use IF/ELSE or STOP after the first "kok vaggutag action off" (my bad again). But if it is not working, you should check with support, as the rule will be fine after this correction.
Don't forget to sync!
Unabel to try the rul now at work wanted to check if this is what you mean?
9202f5c6e6edd98c7ac2a396664e3c4f
And when I test rules will this rule with schedule work?
9ebaa0d9c46b8b0ccec708e67d563c52
Or could this work with a virtual switch that starts a schedule?
42025de701d5801efc3c02d4149de2ec
Why Is not any one from Zipato helping me to create this simple rules?
Socket ON Timer Switch
Socket OFF switch if Socket On by timer
Socket ON Schedule trigger by Virtual switch
Socket OFF Schedule
you make it to complex..
What I want to do is:
Simpel timer switch that turns on when I press the wall button and make the socket stay on for 50 min. And if I push the same button again the socket will turn off.
At the same time I want to have a schedule that is triggered by my Iphone with a simple click. So if I wake upp early to go to work I want to wake up to fresh coffe and that it turns of before I leave home at 6:00
But lets say I don't work early one day, and I don't want the socket to turn on that day then I want to easy turn off the schedule.
Is this to complicated? A little like the iPhones scheduled alarms you can hav on or off you can have on for every working day and off when you don't work.
But att the moment I can't even toggle the timer on and of?
Pleas help!
And or explaining how it works or directing me to where I can read abut it. Just did a forum search, 483 questions about ruls?
Is that ok.
Actually, it is not bad at all. Considering that there are more then 100.000 rules created so far.
Whoooooo.... then it is ok. But could you not take 30-40 seconds to post a rule that works. Goggling around to get help is quiet exhausting. Example why did the rule work if I used any stat but not on state?
When I get a hang of this han how it works I will not bother you and the forum so much.
Maybe make my own explanation videos.
your 1e try is the best correct one.
you have to make the sensor any state only in the when block
The socket will not turn of!
2a45413b19485cd8bec61194544255cf
please check out my comment above (below your previous photo)
Hope there is a solution to al this tomorrow? Going to bed now.
4861541a8b7c9e2229b6d4451f5f9e80
Rule number 10 and 11 works as it should. can't understand why a ANY state should be there it is not when ANY of the two commands are send I want the rule to trigger only when the button is pushed?
Now I only have to understand why it is works, and what is doing what, and also get the virtual switch to turn on the schedule rule. And understand the JOIN block?
But honestly I can't understand why this simple thing had to be this complicated and why the CEO answered wrong 2 times and then expect customers to know how to do.
Any way without complaint to much I am very happy to play around and start getting things to work. Only the rest left:-)
