HTTP Request not working
Nicolas shared this problem 11 years ago
Another day full of bugs in Zipato World... :(
I was fool enough to try to modify a rule (which was working fine for a few months) and trust Zipato that everything will work flawlessly.
How stupid I was!!! I modified the IP address of one http request and...
After modifying the rule none of the HTTP Request used in the rule are working! Event requests I didn't touch. Of course the request is working because I tried it with my web browser.
Worst, the second part of my rule (used for disarming alarm) is not working anymore.
I tried to create a new rule from scratch and HTTP requests are still not working :( Only old HTTP Requests made a long time ago in other rules are still working.
I opened two tickets and I hope Zipato will fix it as soon as possible.
Replies (21)
Maybe the sync is not working anymore because a rule is not right anymore.
Try making a new rule that is very simple and see it that one works.
Thank you HeroS for your advice.
Unfortunately I tried a simple rule with only one http request inside and it didn't work.
Only old rules are working, all new rules (or updated rules) never fired http requests.
Try a rule without a http request. Just turn on a light or something. To see if this on works and if the sync work.
Yes when I add a rule :
1/ Turn the light on
2/ Send HTTP Request
Only the action "Trun the light on" is activated. The HTTP Request is not working.
I am sure the HTTP Request is working since I am using the same URL on another (old) rule.
Sorry, than i can't help you. There where some more people with http request problems..but i can't find the topic.
They upgraded to the last firmware. Do this through the API.
I understand there is nothing you can do :)
I am not sure it is related to the firmware and I prefer to wait for an official answer from Zipato.
Same Problem for a couple of days without doing anything
Support answser :
Hello,please update your Zipabox to the latest Beta firmware available. After you finish updating firmware please synchronizeyour rules again. Please also note that during the Rule(s) synchronization all of Rules are complied into one script anddownloaded to the Zipabox from Zipato Cloud Server. Because of this, if there is one invalid rule, java compiler will failduring the rule synchronization and a whole script will become invalid. In that case Rules should be examined for anerror and the best way to debug is to disable last modified or created Rule. If invalid Rule is disabled and synchronizationis repeated, script will pass Java compiler and Rules will become operational.Best regards,Hrvoje
but it does not work :(
With the new BETA some of other scripts are not working longer , and the post http does not work either.
Wasted my entire evening trying to fix this - Thank you Zipato.
how did you fix this ?
I think he was only trying to fix this, he didn't say he succeeded :D
As for me it is working again without doing nothing, I don't know if I should be relieved or not...
Only one http request is still not working and I still don't understand why. I prefer to wait for a final firmware instead of installing a beta firmware for now.
Making new rules works ( just copy the old which are not working), but http post is still not working.
Please upgrade to new beta now.
Beta 5b....the post http are working now but not the rest of the newscript I'have juste made for an hour. :{
I guess some trouble with the variables (the new beta put them to 0 ?) Its too late now, some scripts are working and other not 100%. Its on the good way, I will try again tomorrow what is running well or not. thanks and good night.
Everythings works now with 5b
Where is this beta firmware, and how do I update to it?
I gave up http requests in rules long ago and like to retest if it works now.
Do you support sending sensor values as arguments now?
I have the same problem. I am using software version 0.9.999.8e. with 2 different zipato boxes.
With the zipato mini (old Software version 0.9.999f, out of date) we don't have the problem.
We use POST and in the URL: https://www.<....>.nl/Zorgapp/log_event.php?pin=1443&system_id=5671BM19&sensor_id=B1&value=1
For us the HTTP command is crucial to communicate with our own software developments.
seems that this is still an problem:
v1.1.22 with simple http request rule seems not working at all :( ..
