How to install new app on Zipatile
Antonio Ugrina shared this question 19 months ago
Hi Zipato team!
I can give you for a beginning big thanks for the support. I successfully transferred to V3 will your full assistance. Thanks!
My question is now, if I try to install new (black) Zipato app from external SD my Zipatile says it has no space. What I can delete without effect on the system later? And, as I have app on the phone, will later all synchronize when starting new app?
As now when I try to synchronize I get “ fail to synchronize the box with server” (old app still) is that the reason?
Thanks for the advice! So, after checking for old Zipato app data and trying to free up space, what do you recommend as the next step? If I still can’t install the new app, is there another way to make it work? Also, do you have any tips on safely deleting unnecessary files without risking system corruption?
Hi Zipato team,
Thanks for the support! I successfully transferred to V3 with your assistance. wcpss wake id portal
When trying to install the new (black) Zipato app from an external SD, my Zipatile says it has no space. What can I delete without affecting the system? Also, will everything synchronize when starting the new app on my phone?
Currently, I get a "fail to synchronize the box with server" error with the old app. Could this be the reason?
Thanks in advance for your help!
You can try deleting old apps, cache, or unused files to free space, but avoid system files. If syncing fails, the old ppsspp app might be causing issues. Try installing Zipato app after clearing space and check if synchronization works.
