No Internet >> some problems
Hi Zipato,
When my internet connection is offline can't login with the app (Android).
Is there away to login local? (the local button doesn't work).
Also when the internet connection is lost and comes online the zipabox doesn't go online automatically. I have to reset the zipabox to get it working again.
Config is:
Zipabox >> Router (gives ip) >> Modem >> Internet
And the last thing that when the internet connection is gone my Smoke detector doesn't go online anymore. I have to reset or rejoin it to get it online.
Replies (7)
"Funny" to see That you have the same problems as I.
- the Internet problem seems to be that the zipabox tries to go online faster then the most routers and when you then got Internet the zipabox have stopped trying. Please start the Internet first, then zipabox. I think fix is comming since I do not want to have manual touch upon power failure.
The smoke detector seems to be a problem with the broadcast that its live. Test run it using the test button, at least mine is still running, just not say so.
Hi Kristian,
Thank you for the reply. I hope that a fix is coming and will try the test button on the smoke detector.
Can you login without internet/login local?
No i cant login wo internet or control any of my devices, it seems like the app freezes.
From another post:
, or you can wait Zipato to publish new mobile APP version with local connection support.
So offline is coming.
Hi Milan,
Oke great! Thanks for the great support. U (Zipato) are doing a great job. Keep up the good work.
Thanks, but i have tried to er-apply the descriptors 3 times and its still offline...
Kristian try the test button.
