How do I configure a custom automation rule to trigger on a device state change or when a specific s
Bonnie219Bailey shared this idea 4 hours ago
I'm trying to set up an automation in my Zipato system, but I'm having trouble with the trigger configuration. I want to create a rule that activates when:
A specific device's state changes (e.g., a light switch is turned ON/OFF, a door sensor changes from Open to Closed).
A sensor value crosses a defined threshold (e.g., a temperature sensor goes above 25°C, or a humidity sensor drops below 40%).
I've looked through the rule creator interface but can't seem to find the exact options to configure these types of triggers reliably. Can anyone provide a step-by-step guide or examples of how to achieve this within the Zipato Rule Creator or through any advanced settings? Are there any specific Liteblue homepage modules or virtual devices I might need for more complex threshold-based triggers? Any guidance would be greatly appreciated!
