MANAGE HEATING BY PILOT WIRE (ELECTRIC RADIATOR)
Vince shared this question 13 years ago
Hello ,
I look for a solution to use my electric radiator by pilot wire by using this plug device :http://maison-et-domotique.com/blog/book-review/zwave-et-fil-pilote-domotiser-son-radiateur/
In the same room, i have 4 radiator all link on the same pilot wire and 1 temparature sensor, and i would like to control them with the solution FGS 221 + leD (the cheapest solution for me)
I've try with rule + scene but it's not flexible as i want and as the climate widget.- How could i use this plug device (FGS221 + led) knowing that I just need 2 order STOP and CONFORT. And integrate it In the climat widget ?ThanksVincent
Replies (10)
To create a thermostat with the Climate widget you need at least one output (you can use FGS221) and one thermometer. After you create a thermostat just configure week program and you are ready to go, thermostat will turn on/off your output according to your settings.
OK But I don't use FGS221 for 1 radiateur, See on the link ,I Use 1 x (FGS221 + 2 * 1N4007) To create a signal i could send in pilot wire of ALL my radiator. If i want to have signal COMFORT the 2 contactor must be OFF. and to STOP, one must be ON and the other must be OFF.
So i think the solution could be create virtual device with
*virtual device OFF = contact 1: ON + 1 contact OFF 2 = Radiateur OFF
*Virtual device ON = Contact 1 : OFF + contact 2 : OFF = radiateur ON
Do you think Is it possible ??
Ok I finally found a solution. Thanks for your reactivity :-)
Quelle solution avez-vous trouvé? Merci.
Hi! On top of that I would like my heater (electric) never turn on if the door of the room is open (based on fgk101). If the door is closed, it should work based on the climate widget explained by Vince. Any idea? Thanks, Frankie
Bonjour Vince,
Top, Merci!
The new Link for the article is here : http://wp.me/p3ld3P-t
and for frankie, if you want the heating Stop when the door is open, the solution is here :
http://wp.me/p3ld3P-3D
