How To Use InterTechno ITW-852 switch
Georg shared this question 11 years ago
I have found some InterTechno light switches with two buttons in my cellar. Now I would like to use it. Any ideas how I could be able to add them?
Thanks a lot
Georg
Maybe it works with the 433 MHz Module
I'am working with the 433 MHz Module. But it seems that the Zipabox has no compatible devices listet like the ITW-852
try other devices in the list, maybe they work ( as for my HAMA remote Powerplugs)
I am a develper at zipato and if you send me your user name (zcerovski@3plus.hr) I may put the latest FW on your box on Monday and you might be able to join and control your switches
Hi Željko, i tried to join the ITW-852. I gues this device is meant with the possible Intertechno entry TWIN WALL SWITCH? I can join it and it works fine for some minutes. But afterwards it doesn´t do anymore the desginated job. Do you have an idea whats wrong? Regards, Marcus
Very Strange. Probably I have figured the problem: According to Intertechno the UP click should be ON. But if I use within the rule generator the ON option nothing works. But while I switch down (according to Interechno OFF) it works. Maybe in the actual Zipabox firmware that´s mixed up?
