Possible to integrate Chuango sensors?
Caroline Andersson shared this question 11 years ago
I have a Chuango G5 alarm system set up and wonder if I can integrate any of the sensors in a new Zipabox Duo setup?
/Anders
432b296f29c00051b4b33d4d94cea9cf
These are the Cuango Devices currently supported by Zipabox (only if 433Mhz module is installed)
you can only use one button from the kayfob
The Door window sensor have one problem:
it you open a door the state goes to open and after 5 sec. to close even if the door is still open
Dear Caroline,
From Chuango G5 alarm system you can integrate RC-80 (Wireless Remote Control), PIR-910 (Wireless Pet-Immune PIR Motion Detector) and DWC-102 (Wireless Door/Window Contact).
Dear Lars,
Did you try re add those devices which are not working correctly.
Please, if the difficulty persist, open a ticket on our support site: support.zipato.com so we could examine this issue. We didn't got any other complaints about this so it could be possible that this is an isolated case in your system.
Best regards
Just added a Chuango door sensor. Twice. Same result. State changes back to closed after 5 seconds regardless of contact position. Is there any way to fix this issue?
