Security module, zones not working
Junk Name shared this problem 11 years ago
On my security module, 2 zones are not working and I continuously receive mails like this:
Read very carefully, this is a very important alarm message.
Your Zipato with serial number 0110261A0E013D2F reported:
Zone: Z4 court circuit in partition Alarme maison was tampered
Details:
Message: tripped
Partition: Alarme maison
Armed: DISARMED
Tripped: true
TripType: TAMPER
Zone UUID: bc8d8420-b35d-46ec-a854-d567b20e46ce
Endpoint: Zone 4 tamper sirène intérieure
Attribute: STATE
State: ACTIVE
Cheers.
Even if I define the zone as "normaly closed" and I put a short circuit wire at input, these zones fails.
Failing zones are zone 3 and zone 4.
It looks like a hardware failure. What can I do ?
Thanks for your help.
I add a picture of security logs. Zone seems to be continuously tamped in and off. Also, if I delete failing zones from my partition, another remaining zone fails :-(
More info again: if I delete all the zones in my partition "Alarme maison", I get mails about siren tamper !
Message: siren tampered
Armed: DISARMED
Tripped: true
TripType: TAMPER
Now, it looks more like a software problem...
And if I remove the partition and recreate it, the problem remains.
Did you find a solution as I also keep getting tampers
