Blinking with all lights when alarm is tripped
David shared this question 11 years ago
I'm trying to blink with all lights when the alarm is tripped but not disarmed.
Tried a couple of different solutions but none that worked. The image below is the one I think is most correct but it never starts blinking.
efcb1c44c21be199215065bbbd8c4905
What is the problem with this solution?
Seems like the repeat thingy doesn't work?
Does it work without the Repeat block? I found the repeat block a bit unreliable. However if I saved and synced multiple times it seemed to "settle down". Crazy but true.
/Marcus
