Last Sync in virtual weather station
Bastian shared this question 11 years ago
i have a problem... my virtual weather station does not sync. I don't get the newest infos. So my light doesn't start on sunset. The last sync was at 18.09 - 03:19
Replies (11)
I have the same problem. About a month ago (if not kore) I have added a couple of virtual weather stations. They were olways updated with like 2-4 hours delay so are useless to include them in rules like when it rains...Yesterday I noticed that they stopped updating since yesterday from around 03:20 - similar time like yours. They are not updating since...
I have contacted support by opening a ticket, but still waiting...no change yet. Very flustrating.
My last update is from 18.9. 03:00 am.
Mine was last synched 9/19/15 @ 22:31, so there appears to be a problem with the synchronization.
Mine was last synched 9/20/15 @ 03:40 ????
Mine was last synched 9/20/15 @ 03:30
Mine was last synched 9/20/15 @ 03:43
Have switched to Plan-B in the meantime (cause it´s the 2nd time in a few weeks now) and trigger all the effected rules with "luminance" - only drawback: no negative offsets.....
Got a sync of weather data again today
Well. I just discovered an interesting thing. Before I did this it was around 15:55. Every station (all 3 of them) that I have in the weather station section in the web ui did have last update around 08:XX (basically in the morning). I went to API / METEO /get
/meteo/attributes/values.
Without any change I just pressed Try out. The log loaded with a complete response.
Now I have went back to the dashboard, the time was still morning, however when I did a browser refresh (pressed F5), voila, the weather station now showed the latest information from 14:46.
So overall it seems that the latest info should be possible to load, just need to send a query.
Perhaps this can be sorted by Zipato as usually m weather information is always a couple of hours old, but in the meantime I see if a rule can solve this problem.
I have set up an easy recurring rule to send a HTTP request, will see if it works. I wonder if it is working as it is a https call not http.
In the meantime I have done another test and now with pictures to prove that this is indeed possible to have latest details in the meteo station. See my pictures (before, after and the api call)
The rule works.nicely. the stations update.
I now have disable the rule to see if the values update. And they do. But I need to refresh the browser (F5) or the app in android.
One thing is strange for sure. Before I did execute this API the first time, I did have late reportings (sometimes half a day old) despite refresh or login, but right now they are as update as possible. Perhaps a one time API call makes the difference...
Which key is used at wunderground.com to get this information? Could it have expired? Is it possible to enter my own key to get information?
