Camera issue...........again..
Darkwing shared this problem 11 years ago
1st issue: I added a camera yesterday, it was not found automatic, so I added it manually and put in the correct url stream. Worked perfect, until today, now it just shows a spinning circle in the player.
2nd issue: I added a second camera today, same one as before, and expected it would not be found so add manually. After adding it, I wanted to put in the stream url, but now the fields are greyed out and can't be updated. It shows shows the default settings and can't be changed.
Why is it that one camera can be added, and then a second one won't allow me to update these fields......why does everything feel so inconsistent with this box? You can never really expect anything, you always need to pray something will work, even if it has worked before........
8a5f9c40d984bfd3eb91dc532d4d7b42
I have the same issue here the 2 cam's was working fine but after upgrade only one worked back
