Aeon Labs Aeotec Z-Wave Gen5 Multisensor not triggering?
Fredrik Karlsson shared this problem 10 years ago
I have a problem getting lights to go on (G2 Aeotec on/off in wall switch, http://aeotec.com/z-wave-in-wall-switches) by motion sensor (the Aeon Labs Aeotec Z-Wave Gen5 Multisensor).
First of all, the motion sensor is working ( I just triggered it here):
68051325eeec7e5b4deedb5fadb99048
Ok, since this is an easy setup, I tried to do it by association:
dfe70fd2aaee900c93f1a02e5535fda8
As you can see, there is an association between the multisensor and the switch triggering the lights. The switch is working fine, I should say also, and I can trigger it remotely, no problem there. However, motion detedted from the sensor will not cause the switch to turn on.
I have also tried the to make use of motion in a rule instead:
64c633084e9600f29f0a36396ff6ca7c
Same switches used, but I never get a push message.
So, ok - what could be wrong here. The motion sensor is obviously working, but I cannot make use of it.
I would be greatful for any help I can get.
Fredrik
Ok, I have had some sucess with in this, but the device is just odd.
What I can do is have two rules like this, and then set the TIMEOUT_AFTER_NO_MOTION setting of the sensor to a value that I want. Then, everything works.a6e1172c934279418250196108d256af
However, I cannot merge these rules into one using an initial "Any" sensor value and then checking for motion.
The lights will then not go on. Odd behaviour.
And a confusing aspect of the device. I can get motion state either as a sensor value or as a meter. Very confusing.
You could do like attached.
Within the IF you can also make an AND to for example use a sensor for light /dark so only when it's dark and there is motion the light will turn on.
Regards,
Slashroot
Ooops, Below the When there should be a JOIN :)
Hope this works for you
O have a MultiSensor 6. But only motion work fine. All other shows “-“ values. I have ticket opened 3 days ago. But don’t found solution.
