What type of sensor is the AEON multisensor?
KoalaBear shared this question 13 years ago
I had some problems with the sensor, but after a firmware upgrade of the sensor, it seems that it was fixed.
Sadly it did not. when I need to changed the "type" of the sensor it doesnt recognized it sensors and meters in the rule generator.
So what is the correct type of the multi sensor?
A new added sensor works fine. But if you want to change description you must give a type.
See attachment
Files: AEON.jpg
Of course, type is the way to get the right icon for it
MULTI sensor, so it is a Motion, Luminance, Temperatuur and humidity...
It makes a difference in rules, right?
It doesn't make difference in rules. Whatever type you choose it will show up in rules under the Sensors and Meters.
Type is currently used only for icons and device naming, and please note that icons are still not available for some of the types (soon it will be), so don't worry if you still have a default icon after choosing a type.
Thats a clear answer
