BIG ROLLER SHUTTER PROBLEM CHACON 433
I have just added a new CHACON ROLLER SHUTTER device since the old one seems to had some troubles since the last firmware update, but now, I'm not able to use this new device into my rules.
It doesn't accept to be used in the block, neither action or set (it doesn't match in).
I tried in Scene but I can only close it and not open it.
With the dashboard (new ui) and the slide buton (0-100%) I can only close it, either with 0% or 100%, it's the same it only close.
I have tu use the old ui to bind this device with my remote to use it (on/off) and it works.
I'm waiting from zipato to do something quickly, because it works very well before, and don't say its my zipato box....
For the others users, just try to add a new roller shutter device and tell me what is working or not!
Have you also the slide 0-100 % (Chacon not somfy or zwave)
So, hurry up please, It cost me 30 € to repair something which was working, and now I will not be able to use it in my rules.
Is it 433mhz?
Is it 433mhz?
Change cero to the seconds it take for it to go upp and down! Otherwise it will not move, because the box think it takes 0 seconds for it to go down!
Then it is probably at Zipatos end. Butt never use the old UI, it is rapidly becoming outdated and buggy I think.
Zipato Answer : (but nothing happends)
we are working on the fix for the controller!The problem is as you noticed with the device descriptor which introduced the slider for exact positioning of the shutters.Unfortunately it was released before testing and we will do our best to fix it in a few days. We have tried the new fix herein the labs, you can test it aswell, go to main device settings of the roller shutter and at the bottom of the screen you willsee 'RE-APPLY DEVICE DESCRIPTORS', if it then works as it should great if not try to re-include the shutter for the newsettings take effect. If it still doesn't work you will have to wait until the new beta firmware.
Firmare 9.999.8e with re add chacon device is working. But only use 0% and 100%, the other % are not really working.
i.e.
My shutter is open , I give 30% in the UI. It close itself when re-oppen itself (I have given the seconds in configuration)
i.e.
Yes, but after two weeks i'm not able again to add a new device.
This is a new issue and you need latest FW which I can provide you, just send me SN of the box
I have the asame problem.
I recommend you to upgrade to the latest beta FW release
