Oregon device, battery changed, do I re-include?
I have changed the battery of my oregon THGR122NX. The battery Icon on the UI was red and empty.
Do I have to do a reset on this device after changing the battery ?
Do I have to re-include this device to the ZIPATO ? If I have to that I have to correct all my rules
Thx
Same question and I would like to know if I can change UUID of this device with Zipato's API ?
Chrys
Chrys
If you have .8k firmware on your box, you should have support for battery change functionality for Oregon sensors. The procedure is as follows:
- in the device manager, under device, select settings -> configuration
- in STATE RESET menu select RESET
- save and synchronize
After that, just wait the device to send a message and check if UI is updated.
NOTE: You must have all transmitting 433 devices included or with no batteries. Otherwise, you might create a conflict.
Also, you might not have a configure menu in the device settings. In that case try the following first:
- under device, menu select settings
- at the bottom, select re-apply device descriptor
- refresh the browser and sync
If that won't work, you will have to re-join the device, but next time you will have to change the batteries, the described procedure should work.
I'm in .8k firmware and it looks run.
Chrys
Chrys
