Always error message 'synchronisation failed'
Jacques shared this problem 10 years ago
Not a Problem
Each time I do a synchronisation I 've got an error message.
1a560b45ac124e130d55693830cb7523
But, in fact, I think the job is done (I suppose), I can try several times, I've got always the same error.
Dear Jacques,
Which firmware do you have on your controller?
Pero
0.999.9.8a
Same error with synchronize device or rules
I've tried with fw 8e, and it works.
I have ZipaMini with firmware 0.9.999f and the same problem, although the last sync is shown correctly. I cannot sync rules either.
It is most likely that you have one or more invalid rules which you're trying to pass up to the compiler. Inspect the latest rules you've made before this condition began, and check if they are properly written. If you still can't find the source of your problems, open a support ticket.
Cheers,
V.B.
i have had this issue for all the betas since .13 Although after I sync a second time,and get failed, I refresh the browser and it is synced. I have disable rules, removed and fixed ones not valid, still get this issue.
