Make the Puzzle language more powerful
Mr Z shared this idea 13 years ago
What about making the puzzle language a litle bit more powerful?
Read: http://community.zipato.com/responses/block-programming-rule-creator
For live testning to see how a more powerful block-language can look like...
Test: http://code.google.com/p/blockly/
That code is open source...
Think there is several things that ZipaBox could use from Blocky to make Rules less limited!
Please...
Otherways there will always be ask for adding text-script like LUA to ZipaBox!
If you do it right this can be very good!
LUA it's a great idea. That will be able to use lua-scripts already use for the vera of fibaro home center
Yes LUA is good, but already other controllers to use if you want LUA ;-)
Let ZipaBox be a simple, easy to use, powerful and rubust solution and make use of the Puzzle to make it programmable by non-programmers!
The Puzzle is what makes ZipaBox special, so just skip LUA and create the Puzzles more powerful :-)
There is other exampel of powerful exampel of how powerful a puzzle-language can be:
Blocky: https://code.google.com/p/blockly/
Scratch: http://beta.scratch.mit.edu/
Both of these exampel is similar to ZipaBox-Puzzle and both is running on the web!
and both of them is USEABLE FROM ALL BROWSERS INCLUDING IPAD!!!!
So I don't see why not fix the iPad problem with Zipato-Puzzle!
I think that puzzle is great. With lua, you have too learn to code... With puzzle, it is simplier ! I precize i know programming in c++ / asm / etc... but for every body, puzzle system is better, and you can do most of thing than lua...
To know the exact solution by which can also get to learn the code for the programming of the C++ and all and that you can do that in the Apple device and that you can also continue with the help of the Apple customer service for the entire guidance regarding that.
I agree that when it comes to learning something new, it's better to use entertaining ways. I can say that when I started learning English, using platforms like promova, you can click here to learn more about it, turned out to be highly useful for me, and my lessons with a tutor are not only educational, but also quite fun.
