Rule not working
Antonio shared this idea 10 years ago
hi,
I am getting crazy with my rule number 4. it does not work.
I explain it.
basically with this rules I want to command the watering system. I created a rule to start watering in the morning (7 am) and in the night (24:00). but I ask to check both weather forecast (precipitation less than 15mm) and a virtual http actuator that I created (I use it in order to stop the rule whenever I want from my mobile phone w/o entering the zipato web page and disabling the rule). basically if the http actuator is on, the rule can start (if all the other condition are ok), otherwise the rule will not start.
now the question is that the rule does not work now.
in the past it worked but always giving problem (I had to reboot the zipato for ex.)
pls help.
Replies (6)
Depends may be on the Firmware version you have installed: on official 8a the HTTP requets work but not of the beta 8e ....
i cant open your screeshot .... i don't know why .. BUT i can share my experience with schedule operator ...
I ve got a problem with a simple light timer ... shut OFF @22:00 pm and light on @8 :00 for my little ecosystem .
since some days i noticed the Light on doesn't work ... and i must activate with my phone manually
I thinking about many hypostesis ...
But i have replaced simply schedule by another schedule and seems to works now ... maybe ...
rule attached again
rule attached again
Files: rule.jpg
ok, solved. to get it working I needed to switch in the rule "Schedulatore irrigatore virtuale" from actuator to control selecting as action the action event "on".
Hey Antonio,
I do not know if two scheduler work. Try this:
Scheduler all 10 min.
if now between time 6:50 and time 7:10 or now between time 23:35 and time 23:55
if precipitation < 15 and switch active
do .....
I use a similiar rule for my garden pump.
