Someone to help me configure a request Locationwith ifttt and Gdrive
            Hi to all
i have a big problem to configure a request with the recipe of ifttt that is:
Ios Location / Google drive.
I don't understand the principle of application i'm too bad :-)
I have the ifttt and google drive accounts
i have the recipe IosLoc/GDrive
I do not know what to put as links in implementation as the pictures in attachement
the aim being to be able to trigger a scene of closing / opening of shutters
thxs to all !!
I forget
The ifttt location area work and i receive the push on my Iphone
I forget
Look at knowledge base for ifttt. The trick is to use a virtual meter and to change its value via ifttt. You then can read the value of the virtual meter in a rule and make some actions. Works very fine and is really easy. You do not need http requests, because the value is changed directly from iftttt, because a virtual meter has its own url.
Ok Andreas thx a lot I'll try something with this :-)
IS THAT RIGHT? with this configuration ?? see attachement please thx a lot !!
I can test this one tomorrow
thx all in advance
thx all in advance
With IFTTT you can now send a http request with out the use of google drive. With the MAKER channel you can do this.
the two rules work
Thx to all !!!
the two rules work
Thx to all !!!
