Sonos start play a radio channel when motion
i want maybe to buy a Sonos if the integration is good. Is it possible to make it to turn on the Sonos 1, then turn on correct radio channel and play it at a volume i have set when motion with a z-wave device in a room? without many special virtual devices and http requests in the rule creator?
Hei Stian!
Just a small test. I have created a rule that triggers when movement in my hallway. The rule will set the volume of my Play:1 in the kitchen to 15, and then start to play. At least, it works if the Play:1 already have the channel of choice selected. Here are the rule:
The list show the "Action" that can be selected. I have only tried "Play"...
In addition to "Set" the "Volume", you may set "URI", but have not any clue what URI means.
Dag
Hei Stian!
Dag
Bare hyggelig!
And here is how Sonos players appears in the Device Browser:
Bare hyggelig!
If you provide an URL that points to a mp3 file, would Sonos play it?
i bought a Sonos:1 today. The zipabox doesnt find it. It is connected to the same network over wifi (set up on a android phone, and working on the phone), and when i go to Add device -> Sonos -> Sonos :1 then i push + and play button and release it so the red Led is blinking. It wont discover it, then time out. But when i log out then log in again it is in IP -> 192.168.2.139 - Sonos :1.
When i press the buttons at devices -> audio player -> sonos player, nothing happens(volume, play, pause..)
Have tried to deleted it and add it again..
weird, I had the same problem with one of Zipaboxes, tried another and worked first time. Can do everything, and now have a zipato key fob that gives my a total 16 options for controlling it. Awesome. If you are having difficulty adding the box contact support. You may need to upgrade your firmware to the latest beta.
I should just mention that I had a lot of problems with the Zipabox going offline and becoming unresponsive. The solution turned out to be to delete all my IP devices such as Sonos Players - support told me that there was a bug that was causing them to consume all the box's memory. They're working on a fix. So, bear that in mind.
I had 3 Sonos Play:1's and 2 Nest thermostats.
