RFID Keypad
How does the RFID Keypad get used? I have it included in the controller and have set the RFID tag as shown in the video, the problem is that nothing happens when I try and use the RFID tag to arm / disarm the system.
I tried pressing the Away button, touching the RFID tag to the keypad and then pressing the Enter button. The problem is that nothing happens.
Is there somewhere I need to tell the Zipato that the keypad is allowed to arm and disarm the system?
You have to learn both home and away in a different slot.
slot 1:
event name: Nathan Home RFID
Now learn using Home button and RFID move over the device
Slot 2:
Event name: Nathan Away RFID
Now learn using the away button and move the RFID over the device.
Use slot 3 and 4 for the code.
slot 1:
Slot 2:
So I need to learn it in both slots before it will work correctly?
So, a family of four cannot have their own codes and keyfobs because this will require 16 slots?
you can add up to 10 different users each with their own keyfob.
I think your statement is very misleading. You have 10 available slots. One slot is used by Home and the other by Away. That cuts you down to 5 users. Add in a PIN code for the Away mode and you need 3 slots per person. So you only have enough slots for 3 people to have the recommended number of codes.
Pretty stupid if you ask me. But then again, I've had an open ticket for 5 weeks and still don't have a functioning security system.
Support doesn't seem to care either. They already have my money and it's been to long to return it now that they've been dragging their feet forever. Let's just say I won't be selling this system to any of my clients.
My business partner and I decided to try one to see if it was a viable solution. Our decision is that it's not even close.
