Unsupported CoCo devices which do work (and not work)
Mello shared this idea 10 years ago
I've successfully added and tested the following CoCo devices which are not formally on the Zipato supported coco device list:
Success:
- ACM-100 (build-in dimmer) added as ACM-300
- ACD-300 (socket dimmer) added as ACM-300
- ACD-200 (socket dimmer) added as ACM-300
- AC-300 (socket dimmer) added as ACM-300
- ACD-1000 (socket switch) added as AC-1000
Failed (trying multiple different device types):
- ACM-250 (build-in dimmer)
Old topics. I have now the rf module but seems it does not work at all. I the ACD-200 tried as you suggest but nothing happens. Normally when you pair the device it should go on/off twice.
I have Domoticz and rflink t works without any problem.
How did you proceed?
When not succesfull have a look; Intertechno / Nexia dimmers. They all have the same protocol: CoCo. There are other brands too using the same protocol.
I tried other brand but nothing happen. I have then swap the rf module and zwave. So rf in first and zwave in second but still nothing. Looks like the module does not send any signal. How can I check if the module is actually working.... I have an rflink arduino which work with every of my rf plug. Zipato please open you protocol and offer the learn feature, for that price is the less you can do really. I feel regret to have to your box... Are you still doing dev? I will really appreciate answer from zipato on this. Also if you purchase extra feature such rules Pro or smart thermostat will be great to transfer these to new box. Know I lost more then 100 euro because of that and any warning before. Please answer I have already a ticket open with your support. If not I will just return the product and find something that has real support and suit my need.
