xiaomi ants camera
Nacho Pavon shared this question 10 years ago
Hi, i have a xiaomi ants camera with night vision, with rtsp, that works with the synology survilliance app, but i can not get it to work with zipato control center... Any idea of how to make it work? I tried putting the same url for the rtsp streaming that i use in the synology, but can not get the stream
Replies (6)
I have a similar issue. Added a few cameras, they worked for a while, and then seem to no longer work..... maybe new FW will fix it.
Any news on Ants camera? mine still not working
Guys, get in touch with support. Maybe that you are not using the correct path even though it might seem to be.
I'm downloading the latest firmware of Xiaomi Ants Camera to try with another FW version.
On VLC everythiongs works fine.
I share to other user my setting:
30356c1defae365051c4b95b0f71a717
You definitely have somethings set up incorrectly. For example the MJPEG and snapshot cannot be a rtsp link but a http link. Also it might be possible that you need to find the link that includes the user and password (like in my low quality or snapshot (also in mjpeg but that is at the end hence you cannot see) - so if you load in vlc it will not ask for credentials but load automatically.
Hi, I have the same problem with yi camera dome. has anyone managed to open the video data stream? what are the configuration parameters?
tks
A
