intermatic pe650
Steve Mutch shared this idea 10 years ago
Anyone got any idea how to setup an Intermatic PE650 Z Wave Tranceiver?
It connect perfectly and controls everything with the supplied Intermatic PE950 Hand Held Remote but I want to configure this with Zipato. When I add the device it appears as a Sigma Designs Multilevel Switch.
Should be able to control Pool Pumps, Actuators, Blower and Heater Temps.
Any ideas or help greatly appreciated.
Steve
interesting, does pressing a button refer to a variable on the multilevel switch? So instance pressing a top left button make the multilevel go to 1. If so you could create a rule for this to activate anything you need.
Have you tried to change the device type in the settings?
Thanks Adrian,
Stupid thing is that when I add the Z Wave device to Zipato the only way to get the controller back on line is to reset the node and readd it which then obviously knocks out the Zipato device.
I tried changing the type but regardless of what I add I only get 0-100% same multi value sensor.
I've sent a mail to Intermatic the company who make this tranciever and see if I get any joy there.
Thanks for the help though
Steve
