Cannot arm or disarm the alarm with mini keypad
Sergio Cadena shared this idea 10 years ago
I install and setup mini keypad, and I setup my tag and password, but when I try to arm or disarm the alarm, it doesn't work.
Replies (7)
Did you set up the tag or password up in the Alarm partition configuration for users?
Yes I did, I created my password with 4 digits and setup a tag. But it doesn't work, I can't arm or disarm it.
Did you set below?
f42cb644f7cd17caf217332da7039f6d
And under users tick alarm rights box?
43b83d5a7a5d7da1a6e02941760e222b
And last but not least, you have to also give every user the right in the alarm pertition. So you go to the alarm part, and user tag, click on the username, and you will get this menu, give every user the rights.
it is a bit cumbersome when you think about it :-)
Thank you, I have another question: I attach image about my users setup, I did setup for my tags, and as well as I setup the tags, how can I setup passwords that I already assigned to keypad?
Sergio, I think the tag doens't use password. The password is only used to manually activate the alarm in the keypad.
Kind Regards
Robert, Sergio is about the possibility to also use the keypad by password. I have never tried this but according to the manual it should be possible to use also code.
perhaps Zipato can help to answer this.
