Allow use of virtual devices in Climate widget
Sebastien AUCOUTURIER shared this idea 13 years ago
Planned
Allow us to use http method device as endpoint :
until zipato can work with 433Mhz sensors, i write a soft for my Oregon temperature/humidity sensors to send data to the zipato through http method device, but i can't use the value gets, in the Climate/Thermostat widget.
It also would be nice to be able to use the HTTP virtual device (sensor) as output for the, for example, heating output since this would make it possible to trigger a rule when heating goes on/off for a thermostat. The rule can then use logics to trigger the actual heating valve (especially when the valve is shared among heating zones).
Are planed for La Crosse Technology too ? Specialy for WS2801 as example, tanks à lot
Any news on this one?
