Adding 433 Mhz modules
Tore Sæbø shared this idea 10 years ago
I'm trying to add Nexa 433MHz modules. Don\t work with the current "new" web gui, but if i try the "OLD APP" (windows) then it's a kind of working, but it's not seamless and give a impression of "prototype" software.
Replies (6)
Try to upgrade to latest beta firmware release .8k or later
Thanks. Was running 0.9.999.8a Are now installing newest Beta. Will reply after testing.
Was running 0.9.999.8a; Adding Nexa PET-910 was possible with the "OLD APP" but not with the "NEW APP". After upgrade to 0.9.999.8k it was not possible to add the NEXA PET-910 at all.
I will have to see tomorrow in the office what is wrong
I'm also new to this; maybe I'm doing something wrong?
With the newest fw (.8k) the inclusion count down from 60 sec last around 10 sec before it stoped and failed with the new app. The old app counted down to 0.
With the .8a fw the inclusion count down went to 0 for the new app but the NEXA PET-910 was not added correct. With the OLD APP and .8a the NEXA PET-910 was added correct.
Looking forward to your reply tomorrow :-)
Try to delete nexa, then synchronize with the controller and then try to re-add it again.
I tested PET-910 and it works fine for me with .8k.
You should try to synchronize with the controller BEFORE including the remote because when you delete the transmitter device, it is not really deleted on the box until you hit the sync and therefore you can't re-include the same transmitter device again.
This might be your problem.
