heating setpoint
I got a problem with my benext heating control I tryd to make a rule to change the heating setpoint.
But I does not seem to work.
I have added a screenshot with the rule
Hello
I have got a little update. I am able to set the set point to 19 degrees but I can't turn it back to 20.
See the rule i the screenshot
with kind regards
Marius
Hello
with kind regards
Marius
I would suggest to put some email messages in your rule. So that you can know which part is executed.
I've created a virtual thermostat. This has 2 advantages:
- 1) that the temperature can be controled in tenths of degrees instead of whole degrees.
-2) that i can control the setpoints for cool/heat within the app. (Because in the app the setpoints can only be read)
