Sunset rule using Virtual Weater station
Thomas shared this problem 10 years ago
In Progress
I did two rules for turn on/off lights at sunset/sunrise. The first one, Turn off the lights at sunrise seems to work fine. But the one that are supposed to turn on the lights at sunset doesn't seems to work. What could be the problem?
I don't see an error. Try an other weatherstation, perhaps is there the error.
try recreating the rule. I have two sunset/sunrise rules that work every morning and afternoon.
Hello Thomas,
please make a change in the Rule so you could again Save it and then Synchronize Rules again. If this doesn't help please open a Ticket at support.zipato.com so we could examine your system.
Hello, didn't help to change make a change but when I created a new rule looking exactly the same, that rule worked. So I deleted the old rule. The new rule work fine.
Can you make a screenshot from te rule you use?
