WOL
Guest shared this idea 13 years ago
Could be interesting to add a virtual switch to Wake On LAN other Mac/PC/NAS on the same network
Was just looking in to this. Great idea!
If you have a webserver or NAS this easy to do.
go to: http://sourceforge.net/projects/wolviaphp/files/wolviaphp/version%202/
Once you "installed" this website you will be able to do a WOL if you follow the procedure. Once you waked up your machine you will be able to Bookmark this URL to repeat this WOL-request.
Create for example a virtual switch an d create a rule:
When Virtual Switch Power On PC is ON
then
HTTP Request using method PUT with the URL you just bookmarked
Regards,
Slashroot
A management or control application's user interface should include the virtual switch. This might be a stand-alone program or a component of a larger network administration tool soccer skills world cup
