Everyspring SP103
Thomas shared this question 10 years ago
I have just installed a Everyspring SP103 outside but it doesn't seems to work as it should. Do you know if there is a way to ajust the sensitivity on SP103? The detektor is added to the zipato but it is detecting motion all the time.
Someone with experience of ZIpato and SP103?
/Thomas
I've had the same problem.
Zipato support answer and steps how to resolve:Go to configuration tab of the motion sensor and then enter the following and see the attached picture for reference:
Option | 1 | 2 | 255
Then "Save" and "Sync", after that refresh the page and go again to the configuration tab of the device. Then check that the sensor
is reporting back the value by clicking the "Retrieve" button, if it returns the value of 255 it is all set to work properly.
