Ability to test/execute a rule on demand and have a rule behave as a scene.
I suggest to add the ability to test/execute a rule on demand : beside the edit/display/disable, have a new icon to test/execute the rule on demand. When this icon is pressed, the rule is executed regardless of the condition of the 'when' block.
Also, have a new sensor block called 'Scene': this sensor could be used in the when block :
when scene
- action 1
- action 2
- if block
- etc ...
in that case, the rule should display as scene that could be applied manually from the scenes (Web UI/iOS/Android).
Bin suggested many times before.
This can be done:
https://community.zipato.com/topic/how-to-create-subroutines
Basically, the key is to make your rules execute when a virtual switch is flipped.
This can be done:
