New attribute for devices with numbers to configure format to show
webscientist shared this idea 10 years ago
For example if the value of a level control is calculated the internal value is 58,333332. So in the device view it is shown as 58,333332 %. This is not very user-friendly. Maybe 58 % would be enough information.
Idea:
Add an additional attribute for the devices with numbers and extend the configuration view by a new input field for it with a label, e.g. "Format:", where the format to show could be added.
Example formats for the number above:
"## %" --> "58 %"
"##,00 %" --> "58,33 %"
If the format field is empty use the standard format as now, otherwise show the number in the customized format.
