Unable to properly customize ZXT 120
Hi there.
I have big problems to properly configure my ZXT 120 module with new interface.
When i select IR mapping (FUJITSU_16 for my AC system) i only can use thermostat. I can't use anymore manual commands except "off" (since yesterday, all was working fine before)
When i try to set up manually IR codes (with IR learning), i can setup only one parameter 25. When i try to add another, the previous one disappears. I tried to launch synchronize between each, reload navigator (ctrl+F5)
Other problem, lots of parameters are not saved when changed like SURROUND IR CONTROL. Choices are ENABLED or DISABLED, but each time i change, value returns to -1
Please help !
