zipato Géolocalisation
Zipato guru shared this question 10 years ago
Hi Zipato users;
Is there any rule that open my door when and turns on light when i'm coming back home .I mean i set a check point in front in my home when i arrive to that point the scene is activated regarding google géolocalisation.
Note I'm ysing zipato with an IOS phone not android .
Thank you in Advance.
The problem is ifttt and your connection to internet. I got mostly answers in the range 1 - 20 seconds.
Look for IFTTT Geolocation, which sends an information via HTTP to your box to a virtual switch and changes its value. This change you can use for a rule in which you can do all you want. BUT: IFTTT does not guarantee short time answer. But I have experimented with it and it works. You can find everything in the knowledge base.
Thank you andreas but you said the time answer is not so fast . How many seconds is the deay of excution of an action once i arrive to that starting point?
I can for exemple change the géolocation starting point not exactly in front of the door but before 50 m for exemple so that once i arrive the delay is no more a problem .What do
Thank you Andreas for sharing informations
ok could you please send me an exemple of activated action through IFTTT regarding google géolocalisation?
Hani,
you know IFTTT? It takes seconds:
Create new receipe. IF trigger is IOS location (select area on the map, which is your the area where a trigger is started. THEN use Maker and put URL of your device. Action is POST and PLAIN TEXT. Ready.
Try it.
yes right i will try if i will find problems i will share it with you
By the way i was using zipato rule creator for free push notification since yesterday was fine and suddently it stopped to work and i no longuerreceive any notification through message configure?
Is that relatedto their cloud ?
let you know i changed the message configure from push to email and worked fine so that way don't send me push notofication is that because i passed the limited number of push but it'sfree?
Thank you for support and nice to meet you friend
is there any special port to specify for this link between IFTTT and zipato because for me the delay is big from 30s to 3 minutes to get the rule activated but any why thanks it works .
How can we increase the response time ?have you got an idea?
